It is currently Thu Aug 21, 2025 11:15 am
PostPosted: Wed Nov 20, 2013 11:58 am
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
I have drawn up a shape in gthang from Mr. Mottola's website: http://liutaiomottola.com/formulae/gthang.htm I want to generate some templates and would rather not deal with printing out tiled pdfs because I would like to keep some extra full sized copies around. It looks like I can only save as dxf. My sister-in-law said she can convert it to dwg and plot it for me. Frankly I am out of my element and want to see if anyone has done it this way and if there were any problems. I'll be emailing the file then waiting until the next time I see them to get the printouts, then I will have to verify the accuracy. I don't want to burden her with several back and fourths. . .
Bryan Bear PMoMC
PostPosted: Wed Nov 20, 2013 12:13 pm
First name: Peter
Last Name: Fenske
City: Leeds
State: Yorkshire
Country: Uk
Should be fine. DXF to DWG is a fairly common conversion and plotting it in one go will be a lot more accurate than piecing them together. It'll certainly save time cutting and sticking!
Pablo Picasso
PostPosted: Wed Nov 20, 2013 12:21 pm
First name: Heath
Last Name: Blair
City: Visalia
I exported the file from G thang and then imported it into Rhino CAD. Printed from there. You can get a free version of Rhino online.
sweat the small stuff.
PostPosted: Wed Nov 20, 2013 2:16 pm
yep, pretty easy. i don't actually print them though, but import them into MC and generate a toolpath to cut a wood template.
g thang is awesome. Mr Mottola deserves many thanks.
PostPosted: Wed Nov 20, 2013 5:29 pm
First name: Trevor
Last Name: Gore
City: Sydney
Have you tried Jon Sevy's little app which works using B-splines rather than blended circles?
http://edge.cs.drexel.edu/GICL/people/sevy/luthierie/software/software.html
(You want the Guitar Design Java Application)
In version 1.1, you can print full size to a .pdf file and then take that to a print shop and get a full size print (or 6). I usually just tape up six A4 sheets, but you have the option. Saves having to run through multiple applications. The .pdf trick might be possible in G-thang, too, but it's a while since I used it. (G-thang, that is).
http://www.goreguitars.com.au
These users thanked the author Trevor Gore for the post: Nick Royle (Fri Jan 31, 2014 11:34 am)
PostPosted: Wed Nov 20, 2013 5:37 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
Thanks all!
Trevor, I have not heard of Jon Sevy's app. I have a design I like in gthang but I think I'll spend some time with Jon's program over the holiday to see if I end up with something I like better. Thanks!
Bryan Bear PMoMC
Users browsing this forum: rbuddy and 19 guests
